Will 17x8 offset 47 work on GC8??
Proper 17" tire size is either 215/45R17 or 225/40R17 or 225/45R17, depending on the width of the tire. Since that's as large as you can run without serious fender surgery, you're really wasting the extra width of your wheels. 7 or 7.5" wide is actually better. But, 8" will be fine. If you already have them run them. But if you're considering acquiring them, then just stick to 17x7.5".
It depends on whether or not you're willing to roll your rear inner fender lip a little bit. If you are, I'd say go with 215/45ZR17 Potenza S-03s. The Dunlop FM901s may even fit in 225/45R17, but I'm almost 100% sure they would be rub-free in 215/45R17, and again that's the best size for the car.
I have a GC and I will be installing 17x7.5 rota subzeros with 22545R17. Mine is lowered and the guy at the wheel shop said it wont rub. I am having doubts on this since 225/45 is a bit bigger. but Im hoping for the best. told him it should be 215/45 or 225/40. well see
Car Info: 02 PSM WRX
Originally Posted by MO REX
I have Rota downshifts (same size and offset) on my 02 WRX with 225/45/17 so3's and the car is lowerd 1.2" in the rear with 1 degree of -camber and they rub when I am pushing hard in corners. Im prety sure there is more room in the fender of a WRX than a GC8 so if I were you I would take Ban's advise and go with a 215.
