widest rim for a 98 legacy gt
Car Info: BH Legacy, white/black
I think you would have a tough time fitting anything wider than a 7.5 inch rim.
You might squeeze an 8 inch with a 225 at the very most, but I doubt it. I would stick with a 7.5 and a 215 or 225 at the very most, and even then you may need a slight fender roll.
Warm Fuzzy Admin
An 8.5 is going to be way too wide, and you won't be able to put a tire wide enough to necessitate that wide of a rim.....
thanks for the reply...I was able to get the 18" volks te37...but unfortunately..it was a 8.5....the guy was selling it to me for 800 bucks too...sigh...sucks...it was also a 5x114....btw...do they make something that can convert my 5x100 to a 5x114 bolt size...i know its far fetch...worth a try...thanks
Originally Posted by Imprezer
My BE is rolling on 17x8 +50 w/ 225/45/17. No issues at all and the car is slammed on CUSCO's.
Warm Fuzzy Admin
They'd seriously stock out at least an inch from the body. I know it sounds like a killer deal, but you should pass, unless you want to buy them then sell them to a 05 STi owner
Warm Fuzzy Admin
BE's have WAY more room than BD or BG's. I have 235's under my BH.
one more thing...its offset is at +48mm....would that affect my wheel bearing?...is it too low?...i think the OEM 16" wheels are +55mm....ooh..i found out I can get a wheel adaptor for a 5x100 to a 5x114 conversion...
here it is:
http://projectnissan.com/ProductCart...&idproduct=847
its so expensive...sigh..
here it is:
NASIOC Slut
