Tire Cables (for snow)
Hi, I just got a 2006 WRX Wagon in OCT. I plan on driving it up to the snow this winter and had a few questions. In the manual it says "Caution: Tire Chains cannot be used on tires listed in the following because of lack of clearance between the tires and vehicle body. - 215/45R17" That's the size I have. I live in socal so I'm not going to get snow tires. I was wondering if I would be able to use cables like..
http://www.vulcantire.com/cgi-local/...=chainz6_c.htm
The wheel gap looks huge which is why I was surprised the manual said not to use tire chains.
I know there is a restriction where I have to have chains unless I have snow tires. I thought I read that using tire chains could void warrenty, but cables have better clearance so Im not even sure if they are necessarily considered tire chains.
Any advice or experience with this would be appreciated.
Car Info: 2011 Impreza 2.5i Dark Gray Metallic
Stock Bridgestone RE92 is All-Season tire (M+S sign on it). You should be able to pass the check point w/ AWD & M+S tires when others (FWD & RWD) are required to put on snow chains/cables. That's the beauty of Subaru! ;-)
There are sometimes when snow chain/cable is required on AWD w/ M+S tires... then I wouldn't drive through at all even I have the snow chain/cable because the condition is too dangerous.
Get some cables and carry them. As long as you have all season tires, you won't need them. Of course, this doesn't mean drive around like an asshat in the snow. A cheap set of cables come in around $35.
The only reason you would need them in combo with M+S tires would be for ice. If you know the place where you are staying has steep roads that could ice up it would be a good idea to have them. As everyone else said you won't need them for the highway if you have M+S. Most of the time if you have a subaru they don't even check the tires @ chain control.
friendly advice!
Originally Posted by debbid
I went to Tahoe with Summer tires on when there was no chain control. Of course, it started to dump snow and my car was having traction issues.
Car Info: 2002 Impreza WRX Wagon
never-mind...I am an idiot
https://www.i-club.com/forums/wheel-tire-59/tire-cables-chains-front-wheels-rear-wheels-151881/
Thanks for the responses.. I probably will go with a cheap $30 set just for the comfort of knowing i have them.
ldivinag
12-28-2005 10:01 AM
