Replacement Tire Recommendations for a 94 Impreza Sedan AWD
Old 05-08-2003 | 09:26 AM
Dexter@tirerack's Avatar
Car Info: 02 WRX Wagon White
m,
The difference between the two sizes is minimal in terms of geometry. I'm guessing you got a better tire in the 185 size than the car came with in the 175 size. There are many more tires available in the 185 size, so it's easier to find a good one there. I'd stick with the upgraded size.
Old 05-08-2003 | 09:42 AM
If you got the exact same tire in the two different sizes, the difference in perfornance handling would be roughly unnoticable. Theoretically, the 185:
*is wider, so better lateral traction/less resistance to hydroplaning
*is taller, so softer ride/less responsiveness
Again, these are theoretical differences. The "seat of the pants" difference between the two tires is neglegible. I recommended the 185 because your options are greater.
DanyoCantDrift
02-27-2008 08:27 PM
av98
11-28-2007 10:55 AM
SoobAeroDude
07-16-2007 12:59 PM
divide_by_zero
01-02-2003 10:27 AM
Quick Reply: Replacement Tire Recommendations for a 94 Impreza Sedan AWD
