PRO N1 wheels,what size Hub centric?
Old 03-06-2004 | 05:05 PM
Fubawu's Avatar
Car Info: Vishnu Wrx Stage Zero
Hi Guys
I recently got a set of PRO n1 wheels 17x7.5 for my 02 WRX.
They sent me 73x56.15 Hub centric rings. They do not fit I know the 56.15 inner rim is good but what do I need for the outer rim?
Thanks for any help
John
Old 03-08-2004 | 08:54 AM
Fubawu's Avatar
Bump..anybody?
Old 03-09-2004 | 05:15 AM
EsoterikWRX's Avatar
Car Info: PSM 2K2 WRX Wagon
What are you asking? The hubcentric rings should fit snugly in between the hub & the bore of the wheel, so the hubrings outer dimension will depend on the wheel's bore.
Old 03-09-2004 | 08:11 AM
Fubawu's Avatar
Thats why I was asking if anyone has these wheels, what did they use. The hub rings that were sent with the wheel are not even close to fitting. I think I found the answer though, 67mm x 56.15mm
John
Old 03-09-2004 | 06:17 PM
If the wheel's center bore is 67mm then i guess you are correct.
RavSpec
43
06-22-2009 10:34 AM
jam007
02-26-2008 12:52 PM
subywrx
12-16-2007 11:26 PM
AWDrifter21
08-29-2004 06:23 PM
tad
06-08-2003 07:57 PM
Quick Reply: PRO N1 wheels,what size Hub centric?
