Oscillating humming sound coming from tires
Old 05-25-2006 | 07:10 AM
06naSTI's Avatar
Car Info: 2006 Black STI
Exclamation Oscillating humming sound coming from tires
I am hearing a slight humming coming from my wheels, mos likely the front but it is dufficult to determine exaclty which one. It gets a bit louder over 90mph.
This comes after a curb impact that put a small dent on the lip of the drivers side rim.
Got the car inspected and every checked out ok so I had it aligned and the got the tires rotated and balanced.
Could there be something that was overlooked? What else should I look for that may cause this sound? Any suggestions?
Old 06-01-2006 | 08:38 PM
dynamicprojeKtz's Avatar
the tires may be "feathering"
Old 06-21-2006 | 10:29 PM
fizay's Avatar
I have the same problem after I hit a curb with my left(driver) side. If you find out what was wrong, please PM, I've had this problem for about a year now, just toolazy/broke to fix it.
Old 07-03-2006 | 09:47 AM
mattsn0w's Avatar
wheel bearing? Did you guys try putting stock wheels or undamaged wheels on?
Old 07-03-2006 | 10:51 AM
-j-'s Avatar
-j-
Car Info: 2006 Audi A3/2007 Civic Si
run your hands over the tires and if it catches, you have flaring/feathering going on. It will not get any better if that is the problem until you change the tires.
As for the noise after hitting a curb, you have a more serious problem than just flaring.
Old 07-03-2006 | 11:46 AM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
What kind of tires are you using?
rnicolas
05-29-2011 12:38 PM
lordcon
09-23-2005 09:23 AM
meilers
04-10-2005 02:46 PM
SilverScoober02
11-14-2004 09:07 PM
Imprezzive
09-14-2003 03:31 PM
