Heavy steering after changing the tyres
Dear All
i have an Impreza 1.6L it comes with 14" wheels, last week i changed the Wheels to 16" Alloy i bought the correct ET 55 as i got an original Subaru Alloys, i also got the correct tyres 205/50 Kumho
i am feeling heavy steering and the steeringwheel tend to turn left if i move slowly or pass by a pumpy road as if the left front tyre is heaver than the right front.
i adjusted everything in the wheels before i install it the car moves in a perfect straight line when i am driving.
should i adjust something or is that from a bad tyres?
well If the tires are more grippy than the 14inchers you had before then they are going to feel more planted and "heavy"
some tires tend to pull no matter how balanced your car is...
i have the exact same feel on my 98 protege. I changed from 185 to 205 and from 14" to 16". The steering wheel definitly got heavier, but I figure it's because the new tires have more grip and wider.
Car Info: MY00RS25
Don't worry. It's just your tires following the road grooves. Some tires do it more than others. It turns to the left usually because the roads are bowed so water runs off to either side of the road and it feels like your tires are being pulled in that direction.
Location: EBAIC- Wondering if I should have taken the blue pill...
Car Info: MY00RS25
Originally Posted by slvrsubywgn
Correct me if I'm wrong, but wouldn't that make your wheel turn to the right?
Grimm
09-06-2005 03:51 PM
