gram lights 57s pro
gram lights 57s pro
I saw these on the ray site and I really want to get them on my 04 sti I know already that I have to get them custom drilled for 5x100 but since there 2 piece I was wondering if its ok to go with the +43 offset on there sight it says that they clear the brembos but then again you cant always believe what you read ... so I wanted to disscuss with you guys before Iwent out and grabed a set of these ... oh I plan to lower with sti pinks also so there is that concern to factor in as well as I want to go with the widest tire that I can run.
thanks guy and feel free to offer up any advice
Just bought a set...
I just bought a set of the exact same wheels you are talking about from a gentleman here in Hawaii...
The wheels are awesome! The fit is perfect...it really fills out the wheel wells...
They are the light gold in 18x8 +43 offset, 225x40x18 Falken ST115... I have a 2004 STI, stock height...absolutely no rubbing so far...I just took my car in to get aligned to ensure longevity and found out that the fronts were way out of spec from the factory...
The person I bought it from (STI808, Norman) slammed his car low which required him to roll all four corners...His car looked awesome!!!
Yes...sorry about the confusion:
Cleaned the car up a bit this morning and tried to snap some shots of the wheels that I would want to see if I was interested in purchasing...here they are:
I will probably invest in some lowering springs or coil-overs to reduce the front end gap...
It's coming along though...
Blitz SUS Drop In
PDE Downpipe
B&B Cat-Back
Cobb Access Port
APS Blow Off Valve
Need Strut Braces
Sway Bars
Coil-Overs
Endlinks
When will it END????
Blitz SUS Drop In
PDE Downpipe
B&B Cat-Back
Cobb Access Port
APS Blow Off Valve
Need Strut Braces
Sway Bars
Coil-Overs
Endlinks
Admin v2.0
Car Info: 02 Black Legacy GT
These rims are super cool. There is one problem with them. RoJa bought the exclusive right to re-sell and re-brand these wheels in the US. So, all 57F-Pro's will now be called RoJa something.
Same wheel, but I would not want to be cought dead rolling on RoJa's.
Location: Under your bed, in your closet, and in your head
Car Info: Corvette Z51
All Gram Lights are going to be RoJa's now?! Sonnuvabeotch!
So if I get a set of Gram Lights in the future, they can be considered JDM then?
i got the same rims you're looking for 18x8 Gram Light 57 pro's +48 offset not 57f. They look bad as hell and make the car look real sleek. According to a couple of guys at Racing Zone they should clear most BBK's. I plan on getting the Project Mu kit so as soon as I do I'll try to post some pics.
