Got A Gap Between The Fender & Tire?
Car Info: STI
We are a new vendor to i-club.com and would like to introduce our wheel spacers to subaru drivers.
www.ichibausa.com
If you have a problem with caliper or need to push your rims flush to your fender, here is the ad tell you how to measure it.
We have 3 different sizes (5MM, 15MM & 25MM)
5MM = 0.197 INCH
15MM = 0.590 INCH
25MM = 0.983 INCH
Before & After
How To Measure?
Make sure you correct the camber after the car dropped!
The widest point of your tire and wheel combination is usually the outside diameter of the tire sidewall. Using a ruler with the straight edge flush with the face of the tire, measure the gap between the outer face of the tire to the inside lip of the fender as shown in the diagram. This will determine the thickness of the spacer you will need.
www.ichibausa.com
5MM = 0.197 INCH
15MM = 0.590 INCH
25MM = 0.983 INCH
Before & After
How To Measure?
