225/45/17- sti recommended tire pressure?
Car Info: 07 subaru wrx
check the driver side door jam,usually on the rear side. Or check your owners manual (if you have one) under 'tires'. Failing that go up to the service drive of any subie dealer and with your most winning smile say "could you look up the oem tire pressure specs for me?"I know you have a wrx but the pressures will be a good place to start,if your at the dealer ask for an sti pres also.these are all gonna be probably in the 32-36 psi range.JUST DON'T GO EXTREME ANYTHING TO START.
matsui56
01-23-2007 10:44 AM
