17x7 offset 55 OK on wrx?
Car Info: 2002 WRX Wagon
sorry if i couldn't find this info with a search. only thing i could find was that 17x7 with 53 offset was ok. is 55mm offset too much on an 02 wrx? any possible problems?
thanks in advance.
thanks in advance.
Originally Posted by slvrsubywgn
The 02-03 stock WRX rims have a 55mm offset also. I'm sure the 04-05's are the same, too.
Location: EBAIC- Wondering if I should have taken the blue pill...
Originally Posted by LMON50
i wasn't sure if offset requirements change with different wheel sizes (e.g. 16" to 17") . are the new 06 wrx 17" wheels 55mm offsets too?
Nope, the requirements don't change. After all, the USDM STi's wheels are 17x7.5" with a 53mm offset. Some people say that higher offset are better for these cars and lower offsets may cause premature wear on your wheel bearings, but I have yet to find proof. I say go with whatever you want and whatever fits on your car
....there have been reports of bearing failures in markets outside the US due to offsets below ~+42....I, personally, wouldn't blink at running a +42 offset(for the 'right wheel') but staying 'over' that is better if at all possible...which is one reason that I bought the SSR Comps....+50 offset
b00staholic
11-28-2012 09:43 PM
beat
06-02-2010 04:31 AM
J-DUBB
09-22-2006 04:06 PM
LukeSTi
08-07-2005 05:55 PM
