02 Impreza max tire size
I just purchased 17"x7.5 48mm Rota rims for my 02 TS Impreza. I would like to put 225x45x17 tires on. Is there a possible problem with rubbing with this tire size. I have read some tire brands are wider than others.
Thanks in advance
Thanks in advance
...:sigh:...What exactly is your Q? What is the widest tire you can stuff under a Impreza? For sedans, probably 255s, for wagons 235s. But that is highly dependant on offset, suspension, tires, & willingness to do slight modification. Or do you want to know if 225s will rub on your otherwise stock TS? (I have to assume that it is stock, otherwise refer to previous sentence.) They most likely will not rub.
Be more specific & you will get a more specific answer. BTW, welcome to i-club.
One more question,
You say that 235 wide tires will fit On my 2002 Stock Impreza TS wagon with slight modification. What sort of modification would this be. I would like to have as much tire on the ground for cornering is why I am asking. Plus I cannot own anything without modifying it in some way. I think the 225's will give me the performance I am looking for, but want to know what is involved to have 235's on the car if I change my mind.
Origami posted by rm6keith
Installing some sort of camber-adjusting parts can allow an experienced shop to dial in more negative camber, which helps handling to a degree and tilts the top of the tire inward with respect to the fender. An extreme amount of negative camber can lead to rapid tire wear on the street. Look at lowered old-school VW Beetles to see what I mean by an excessive amount of negative camber - it negates part of the benefit of using wider tires in the first place.
If your car isn't already lowered with aftermarket suspension pieces, consider that going to the widest tire that will fit a stock car may cause some headaches after the suspension mods.
Donnie_Doritos
03-30-2008 10:57 AM
Itazura
Vendor Group Buys/Specials
10-06-2005 06:49 PM
DaWorstPlaya
09-23-2003 07:34 AM
