Oakos Shorty Downpipe
Description of DP taken from www.oakos.com
-The 2.5" 304 stainless steel tubing is CNC mandrel bent to exacting tolerances
-Mandrel bending preserves the inner diameter of the tubing helping to ensure maximum exhaust flow
-Computer Designed 304 Stainless Steel Bracket
-3/8" thick laser cut mild steel flanges
-Entirely TIG welded using stainless steel filler rod
-Direct bolt in replacement for the stock downpipe
-Weighs only 5.85lbs; less than half the weight of the stock down pipe which weighs 12.35lbs!
-Much higher flow than the restrictive stock part
-The stock turbo heat shield bolts right back on, no cutting or grinding necessary!
-This down pipe is made exclusively for OAKOS Automotive by a QS/ISO certified, tier one automotive supplier. This same company builds all the exhaust manifolds for Aston Martin and also for many other automakers.
-Note: Off Road Use Only - Not Legal For Road Going Vehicles
Pic from OAKOS
This will be off my car tomorrow and ready to go. 100 picked up or 112 shipped.
Pic from OAKOS
OakosAutomotive
Engine and Drivetrain
12-16-2006 09:42 AM
nerrad5
18
07-27-2004 06:46 PM
