FS: Rear Cusco Pillowball upper mounts
Car Info: 2004 WRX
i bought these 2 weeks ago...installed them on the carfor 2 days...realized my problem was the struts...got new KYB AGX struts...went to re-install the camber plates on my car only to have them NOT fit my new struts...now im stuck with these
nakubie suggested i get them re-threaded for the KYB's...i did...well they aren't for me...you can buy new center nuts for $19 bux each from www.napsusa.com (you'd need 2)
like i said..i put them on...put like 20 miles on em.
bought new from rally sport direct for $250 for the rear. they fit the OEM struts no problem with the center nuts they provided.
im looking for at least 200 for them..or make a reasonable offer
info from cusco:
Pillow Ball Upper Mount
Features:Controls unwanted forces under acceleration and braking. Both center lock and camber adjustable upper pillow ball mounts improve steering response and performance. A dramatic increase in stability over bumps and high-speed corners keeps you on your intended line, while stability and safety under corner braking is also increased.
Specification:Both center lock and camber adjustable type available. 6mm thick plate uses 2017S duralumin.
info from cusco:
darkangelgrafix
02-12-2011 11:58 PM
sosube
07-12-2007 10:56 PM
firebert
03-19-2007 10:34 PM
gruppe-s
12-08-2005 06:02 PM
D E K R A
12-29-2004 04:41 PM
