Will lowering my WRX be bad?
Old 04-01-2003 | 02:37 AM
teiva-boy's Avatar
Car Info: Boosted Geo Prizm
Yeah you might lower your center of gravity and actually take a turn at a higher rate of speed. That is something that you dont want to do
Old 04-01-2003 | 11:17 AM
Daredevil's Avatar
how much are you lowering it?
if its 2 inches or more, you would want to get a camber kit, so you wouldn't wear down the tires too much
but anything that is under 2 inches is ok but camber bolts can't hurt
im getting the Eibach Pro Kit, lowers it 1.3 in front and 1.1 in rear and I hear good things
Old 04-04-2003 | 12:50 PM
WRXURV8's Avatar
There are tons of forums on this subject. I have chosen the Eibachs for my needs (daily driver / crappy roads). Adverse affects may be tire wear, your OEM shocks will wear out quicker if you choose not to go with coilovers or the Koni Inserts, and of course you will have slightly less ground clearance. The camber bolts never hurt. They are only around $30.00.
Old 04-04-2003 | 05:53 PM
teiva-boy's Avatar
Originally posted by BluWrX.03
Hehe. Well the reason i ask is because i have heard that lowering your car that has awd is not good. Me, i can see no reason as to why this would be bad, so i figured that id ask the rexers for info.
Well lower it too much and you risk premature wear on your axles and perhaps suspension. But up to 2" is for the most part "safe."
Racecomp Engineering
05-22-2008 08:54 AM
subieguy83
09-12-2005 11:46 AM
Z Man
01-13-2003 09:59 PM
Quick Reply: Will lowering my WRX be bad?
