under/oversteer questions
Old 04-03-2003 | 08:31 PM
capt'n'caveman's Avatar
Car Info: platinum rex wagon
couple of quick question bout the wrx wagon.....in stock form, does it have the tendancy to over or understeer?
also, will adding a larger dia. rear sway bar causes the car to over or understeer?
danx
Old 04-03-2003 | 10:27 PM
Kostamojen's Avatar
NASIOC Slut
Stock = Understeer
Larger REAR swaybar = More oversteer.
Old 04-03-2003 | 10:36 PM
Originally posted by Kostamojen
Stock = Understeer
Well... more like larger Rear Sway Bar= less or almost no understeer. Very hard to totally get rid of it without new struts too.
Old 04-04-2003 | 10:21 AM
danx for the info.......
is it that hard to get rid of understeer on the wagon? dang
i'm going to be dropping in cusco front and rear sway bars, i believe the fronts are 21 mm and the rear is adj. from 21, 22, and 23 mm.........should i set the rear to 23 mm then if i want a more neutral feel to the car
i don't do track event....but do occasional canyon runs
Old 04-04-2003 | 01:28 PM
That should have a pretty good feel to it. I wouldn't call it neutral exactly, but pretty close. Close enough to be faster and noticeably easier to rotate than stock.
Old 04-08-2003 | 01:09 AM
radioflyer's Avatar
Car Info: 02 Subaru WRX Sedan
captn'...
when dialing in/out oversteer with swaybars, you want to concentrate on the RELATIONSHIP between the front to rear. my suggestion is to leave the stock front bar but upgrade the rear to a 20 or 22mm bar. the cusco adjustable is a good piece, i'd install is in it's middle position.
the reason why i don't generally like going crazy with huge front and rear swaybars is because they effectively undo the suspension's independent-ness that was engineered into the system. wen i had a wagon, i upgraded the rear bar to a 24mm bar and it made the rear suspension feel like a truck. but it did let me rotate the car like crazy
whatever you choose, just remember that the larger the rear bar is compared to the front = more oversteer.
hope this helps,
-james
Old 04-08-2003 | 10:47 PM
The wagon has more neutral weight balance, which means it takes less effort to get more grip in the rear. Adding the 20mm to the wagon is like putting a 22mm on a sedan.
Krinkov
10-15-2008 10:05 PM
williaty
07-10-2006 04:47 PM
Schlogen
04-08-2004 08:52 PM
veloLexus
03-25-2003 01:32 PM
jetguy
01-23-2003 11:59 AM
Quick Reply: under/oversteer questions
