touge suspention
touge suspention
i'm looking into getting some touge suspention for my 02 wrx sedan once the snow melts. i want it to be stiff enough to handle, but to be easily controable and won't snap my spinal cord on bad tramac surfaces. i don't go on the dirt ever, and i don't do that much track. so i was thinking of maybe the sti spec c suspention or the cusco comp s, or something around that price range. i don't want anything like the tein ra or cusco 2r. does anyone knows what kind of suspention set up works best for touge? what's the spring rate on the spec c suspention? is there any other options around that price range?
any and every input is appriciated
thanks
thanks
Dahveed aka Robin Hood
what touge do you have near you in the USA?
I assume by that you mean good backroad handling, right?
Gather the entire V8 Spec C bits, or at least get Tein HG Coilovers.
You can't go wrong either way...
Old School
Car Info: '99 RBP GM6
Originally posted by hashiriya
All touge means (far as I know) is "mountain pass". The USA has no shortage of mountain passes, no reason you can't run a proper touge in the States.
anyone with a lot of money to blow? buy some land, and build a touge!
-Gagan
umm i thought touge just ment mountain roads, it's a *** word.
anyways, i drive around lake arrowhead, but it's snowing these days, and it won't clear untill april
thanks for all of your imputs, i was thinking of the spec c suspention, but i just have no idea how stiff it is.
how big of a difference is there between the stock spec c springs and the sti lowering springs?
how big of a difference is there between the 2 springs above and the sti tarmac springs and sturts?
thanks for all the imput guys!!
Originally posted by joltdudeuc
Oh,
and get these for that perfect back road setup:
Ver8 Sti Struts (Adjustables if you can afford them)
Ver8 STi Lowering Springs (pink)
Ver8 STi Tophats
-Gagan
Oh,
Ver8 STi Tophats
-Gagan
Originally posted by banpreso
i just thought maybe the spec c, not the sti
I have Ver 8 Spec C struts/ springs come with the struts. My car handles better with those than stock USDM STi struts, ride is firmer and less bouncy. According to this chart, the pink lowering springs has higher spring rate than stock ver 7 Spec C. IMHO, it's great for touge and I go like on weekly bases.
http://www.ravensblade-impreza.com/t...ng/spring.html
Oh,
Ver8 STi Tophats
-Gagan
Oh,
Ver8 STi Tophats
-Gagan
But this set up will cost you a few dollars so you may want to just try some sway bars, a good bushing kit (STi group-N), and maybe some good tires on 17" rims.
Lowball
