Torque specs for RSB & FSB & Endlinks???
Car Info: Stage 4+ Bugeye
Mostly on cars there are 5 specs:
Not tight enough
Snug
Tight
Super Tight
Hernia Inducing
I have found that the swaybars should be inbetween tight and supertight so they dont start clunking.
Regular grease will work, and some require a grease gun so you can inject the grease into them.
Good Luck
Rush
Not tight enough
Snug
Tight
Super Tight
Hernia Inducing
Good Luck
Rush
They are in the manual available on the web, I can not recall the specs right now. IMHO the torque is important as you do not want to break the bolt, bind the bearing or distort the sleeve. Having said that,I could not get my tourque wrench to some of the bolts so I did tighten by guess. I used white lithium waterproof bearing grease I had around. No squeeks a year later.
Swaybar -> Endlink
33 ft-lbs front
33 ft-lbs rear
Endlink -> Control arm(Front)
22 ft-lbs
Endlink -> Rear Lateral Link (Rear)
33 ft-lbs
Taken from 2002 WRX sedan service manual
33 ft-lbs front
33 ft-lbs rear
22 ft-lbs
33 ft-lbs
LegAC_GT
08-29-2014 07:57 AM
