tire wear w/ tein ss??
i just purchased this suspension setup. would i have camber problems on these coilovers? i came from a honda where camber was once a problem.
i jus wanna get rid of the wheel gap for now, then maybe lower more when i get rims/tires.
will i get any tire ware?
front camber is adjustable, rear is not. However if you only lower the car to within an inch or so in the rear, a camber kit maynot be needed and your mechanic can keep things within spec. There is a small amount of play in the system to make up for a few tenths of a degree.
If you truly need a camber kit, it's mainly eccentric bolts and they cost <$30 a set.
teiva-boy is right. if you only lower about 1inch or so
you dont necessarily need to get an alignment as it is still within
factory height tolerances.
but, its a good idea to atleast get the front camber and
toe's corrected if you do a lot of long distance driving.
Scooby_WL
10-03-2003 11:24 AM
