Tein RA VS. Tein Flex
1 way height adj. is where you loosten your spring to lower your car and
2 way is where there is a completly seperate setting to lower and raise your car
Tein SS Coilovers
*1-way Height Adjustment
93-01 2.5RS: (Front: -50~-14mm; Rear: -42~-30mm)
Recommended: (Front: -30mm; Rear: -25mm)
02+ WRX/STi: (Front: -80~-32mm; Rear: -44~-24mm)
Recommended: (Front: -66mm; Rear: -33mm)
*Compatible with Tein's EDFC damping controller
*16-level damping adjustment
*Includes main springs and helper springs
93-01 2.5RS: (Front: 7kg, 392 lbs; Rear: 6kg, 336 lbs)
02+ WRX/STi: (Front: 5kg, 280 lbs; Rear: 5kg, 280 lbs)
*2.5 RS kit does not include upper mounts
*WRX/STi kit does include upper mounts
|CLOSE|
Tein SS Coilovers
|CLOSE|
TENAZ
Wanted
05-08-2008 05:18 PM
hp
05-30-2006 01:41 PM
Daredevil
24
09-29-2003 08:24 AM
t-wrexxx
05-16-2003 01:49 AM
