Swaybar or endlinks?
I want to improve turn in, and corner flatter. I also want to make the handling a little more neutral and kill some of the nasty understeer. Should I get endlinks or a swaybar? I do occasionally do a little mudding, and read that endlinks can cause problems offroad. True?
That is an option, but I dont want my car to snap around if I get off the gas mid-corner. That is what I have heard happens with that setup. I want more neutral, not more dangerous. If I autocrossed, it would be a different story.
Car Info: 2002 White WRX Wagon (WWW)
Re: Swaybar or endlinks?
don't just get endlinks
you should get both
i have cusco rear adj sway with solid helix endlinks, and i do a lot of off roading and have never had a problem.
when i installed it that was my only suspension mod and it made the car so much more neutral. get the adj sway bar cause then you can get it so it feels just right for you
you should get both
SpeeDyScooBy
25
05-01-2008 09:26 PM
Sti"izzle"
08-16-2005 10:31 AM
links_courses
10-22-2003 02:44 AM
WRXnSF
Subaru OEM Parts For Sale
12-16-2002 10:54 AM
Edvig
12-09-2002 08:42 PM
