sway bar help! ( 94 Impreza L )
Originally Posted by rau
so i looked underneath the car to check on my exaust ( scraped ) and i noticed that i dont have a rear sway bar. is there a way that i can install one? and what sixe should i go front/rear to get neutral handling?
No idea what size it is.
Here's an install of one for ya with pics so you can see what needs to be done
http://www.scoobymods.com/forums/showthread.php?t=23
Car Info: 96' Impreza GM4
I have a 18mm RSB on my 96 L, I've heard that a 20mm is a better choice however. You might be able to find the mounting hardware you need at a junkyard. I'll try to snap some pics later to show you how the L looks back there with a RSB.
NASIOC Slut
You will need:
A swaybar (any 93-03 rear swaybar will work, shoot for an 18mm (WRX wagon 02-03) or 20mm (WRX sedan 02-03) rear swaybar, and the corresponding bushings.
Rear endlinks.
Rear endlink bolts (some aftermarket endlinks come with bolts)
Rear swaybar mounts.
RS or other model ~97-01 rear control links with the endlink attachment points (most expensive part of adding a swaybar to a non-swaybar L).
Rear endlinks.
sabrebluewhale
07-07-2008 04:23 PM
JunGdB
26
05-09-2006 01:07 PM
DaFastOne
06-22-2005 03:53 PM
Rat
06-05-2005 11:04 PM
GottaREX
02-25-2004 09:37 AM
