Swapping out suspension on 1995 Impreza L AWD
Car Info: 95 Impreza Wagon... 1.8 Litres of fury!
Hey guys, I'm new to this particular forum and I have a question for you. I just bought some suspension parts from a WRX Sedan including shocks, springs, and front control arms with ball joints. What I would like to know is what can I use? My car is a 1995 Impreza L Wagon 1.8L AWD 5 spd with 4 wheel disc and ABS.
I'm expecting the control arms not to be compatible because of a different mounting point but I;m not totally sure. Also I know I'll need to get springs from a wagon for the rear.
Thanks in advance.
-Matt
Thanks in advance.
-Matt
Car Info: 03' Subaru Impreza WRX - R.I.P.
Matt-
I am very sure that the control arms will not work, but don't be too sure you can't use the Struts/Springs. You may have to do some custom work (moving brackets on the strut, or brake line adjustment, etc.) I was doing some research about the suspension differences between a 95 L' and a WRX, and I found the main differences here-
Strut/springs/coilovers - different
Rear sway - fits (not found on the 95' L stock)
front sway - different
Rear Lateral arm/trailing arms - fits
Front control arms - different
F/R endlinks - fits
aftermarket parts
F/R Strut tower bars - different
ALK - fits
Lower arm bar - ?
V-underbraces - ?
for reference: (prices too)
http://www.subaruparts.com/catalog/?section=160
F/R endlinks - fits
aftermarket parts
ALK - fits
Lower arm bar - ?
V-underbraces - ?
choppy001
02-25-2006 12:04 AM
gixxeric
11-15-2004 09:52 PM
wombatsauce
11-10-2004 02:22 PM
