steering rack bushing installation...AAAARRRRGG!
Car Info: '03 PSM Sedan
this afternoon i tried to install a set of Noltec steering rack bushings into my WRX in the hopes of firming up the steering feel in the car. i used the instructions here:
http://www.ravensblade-impreza.com/m.../steering.html
take particular note of the section:
if by coaxing he means "epic wrestling match under a car using only the very tips of your fingers and teeth" then i guess it's correct.
to make a long story short, i didn't get the damn bushings installed (i gave up on the passenger side bushing and put the stocker back i). does anyone have any tips from when they've done this, or is this a 'no one does it because it's too freakin' hard' mod?
Once you have the stock bushing out, replace it with the hardened bushing that is more rounded in shape. Open up the cut in the new one, slip one edge over the main tube, and "roll" it around the tube. It should go right around with a bit of coaxing.
yeah, that's kinda what i've been thinking. maybe i'll have them do my ALK while i'm there too. they can probably do it in about a third of the time that it would take me.
use a hair dryer or heat gun to get the bushing nice n warm, then throw it on there. also, some soapy water might help.
Car Info: 2002 Impreza 2.5 RS Midnight Black Pearl
Dude...tha Passanger side one is SOOO EASY. I did that in like 15 mins.
If you think that one is hard...then the Drivers side you will NEVER GET DONE. The Driver's side took me about 2 hours to get in.
Are you sure your putting the correct one in? Did you remove the mount completly and slide it over to the side? Did you cut the little nub off? Pull on the rack a little, it should come down pretty easy. Seriously...the Pass. side one is a very easy one to do in comparison to the drivers side.
Speed Element
11-06-2007 12:30 PM
Speed Element
05-01-2007 05:16 PM
