Squeal from wheels without applying brakes?
Old 04-19-2005 | 05:21 AM
Wakeman's Avatar
Car Info: '00 BRP 2.5RS 5spd Coupe
Question Squeal from wheels without applying brakes?
Hi Folks,
I'm pretty sure that it's just time for some new pads, but I thought I'd pick your brains anyway to make sure it's not something more serious.
At pretty much any speed, slow cruising to highway, my rear wheels are making this high pitch squeal, and it only stops when I hit the brakes. I thought the squeal tabs on the pads were only supposed to make noise when you used the brakes, not the other way around.
I've got a '00 RS coupe with a stock brake setup if that helps any one. I'm actually just waiting for my Axxis Ultimates to show up so that I can swap on some slotted WRX front rotors (already bought the brackets).
Thanks in advance.
Old 04-19-2005 | 07:17 AM
RedStage's Avatar
Car Info: Ver IV STi Wagon
Took mine in for same reason, was told that my rotors are slightly warped.
Old 04-19-2005 | 12:45 PM
Wakeman's Avatar
Well, I guess it's good I've got 4 new slotted rotors ready to go on!
If that and the new pads doesn't fix it, then I'm gonna be worried... Bearings?
Old 04-24-2005 | 06:25 PM
AwDfun's Avatar
Originally Posted by Docent
I got exactly the same problem. In my case the squeal from rear wheels starts after ~ 20 miles of driving (pads heating up?). I have Impreza WRX 2002, and Stoptech stage 2 kit (slotted rotors, Axxis Ultimate pads) with 15K miles on it. Rear pads are still in good shape.
I brought the car to dealer with this problem. They didn't find anything wrong with the brakes. Next thing I am going to try anti-squeal lubricant and to bevel the outer edges of brake pads.
I started having the same problem about a month ago, but recently it just went away, and I haven't had a problem since.
Old 04-24-2005 | 11:21 PM
"Warped" rotors normally wouldn't cause a squealing sound, just a vibration. pull all of your pads out, there may be some debris stuck in a caliper somewhere. It's also unlikely to be a wheel bearing, or it would have totally given out by now probably. Those manifest themselves as a whonky, whirring sound and clunking or vibration beforem really making noise.
Old 04-25-2005 | 07:25 AM
RedStage's Avatar
Mine is not a constant squeal, but intermittent....(squeal, no squeal, squeal, no squeal...etc, etc, etc)
They said the rear discs were just warped enough to be making minor contact with the pads.
I'm thinking that the 4 pots up front have something to do with uneven braking force in the rear?
Should I try getting the rear discs turned? I have heard both sides on turning discs but still don't know which is best (cant spring on new rotors right now.)
Please advise.
Old 04-25-2005 | 12:06 PM
Fubawu's Avatar
Car Info: Vishnu Wrx Stage Zero
I have the exact same thing, but mine happens at slow speeds. I just changed the fronts to 4-pots. I did not think to check the rears! I will have to take a look.
John
Old 05-20-2005 | 08:10 AM
Fubawu's Avatar
A month later and this post has not moved. Boy things move slow here.
Old 05-20-2005 | 11:37 AM
You left a comment, not a question. What were we supposed to be posting here?
Old 05-20-2005 | 02:35 PM
Fubawu's Avatar
It has nothing to do with my old post, It's not a slam against anyone. I would like to see a little more action on these pages.
John
Old 05-20-2005 | 09:45 PM
svek's Avatar
Car Info: '99 2.5rs - Rally Blue
my rear brakes are drum
but anyway this happened to me a while back. my brakes squeal REALLY bad at low speeds like coming up to a stop sign. but one time it made the noise without me pressing the brake. i was quite confused.
________
Uhwh
Old 06-07-2005 | 03:14 AM
What pads do you have in the rear?
Quick Reply: Squeal from wheels without applying brakes?
