Replacement Rotos for Prodrive/Alcon
Hi all,
I have a set of Prodrive OEM Alcon 4 pod brake installed on my 2002 WRX. They are using 330mm by 28mm rotors one solid piece.
The rotors and the pads are on their last leg of service and I am looking for replacement. However, I am looking for a 2 piece rotor (Rotor and Hat) as well as brake pads.
Went through a couple of US web sites. Wrote a couple of mails to Performance Friction with no replies.
Wonder if anyone can help me here. I am desperate.
(Note: The Prodrive brake kit is the same as the BAER Pro brake kit. Anyone knows the Alcon model code for the Caliper?)
StopTechs are 328x28mm. I am not sure about the way it is offset though. But I doubt that 2mm in diameter is going to make a HUGE difference. I do know that replacement rotors for that brake kit is really expensive and not even funny.
Have you contacted Baer?
A lot of their two piece rotors are based on Alcon dimensions and I know they do a 330mm x 28mm two piece rotor.
Our 13" two piece Subaru rotors are to suit an STi WRX which are 326mm x 30mm fitted with Brembo calipers. I doubt they will fit.
Originally posted by SGREX
Hi Steve, any contacts for me?
3108W. Thomas Rd, Suite 1201
Phoenix, Az 85017-5306
Phone +1 602 233 1411
Fax +1 602 352 8445
The only contact names I have are the owners. I will find out who to talk to and let you know.
Sorry I just saw that you are in Singapore.
You could try,
International Motor Sports promotions
Hong Kong,
ph +852 255 53939
fax +852 250 31128
They are an Alcon distributor and should have access to the two piece version of your Prodrive rotor.
Another lead; The one piece Prodrive rotor is based on a C4 Corvette design and you may be able to source a Corvette two piece to suit. It will probably be cheaper.
You could try,
Hong Kong,
ph +852 255 53939
fax +852 250 31128
Thanks Steve. C4 Corvette runs on same PCD as a WRX?
Subaru PCD = 100mm
Most of these type of rotors are stocked as blanks with no stud holes. You'll need to check with the supplier.
Baer Contact;
Craig Hedman
CraigH@baer.com
602-233.1411
drpsnwbrdr
01-14-2014 01:25 PM
DoomE.Q.
13
04-17-2004 07:38 AM
