Rear sway bar or springs
Old 12-09-2002, 07:29 PM
ted1186's Avatar
Car Info: 2001 Legacy L
Which is more effective? Which is a better deal for a BE?
ted1186 is offline
Old 12-10-2002, 09:55 AM
AKSubie's Avatar
I would agree with nitrohuffer, first would be to improve the rubber. I have an adjustable rear swaybar as well, and it does induce some oversteer, even on the middle setting. Springs are definitely difficult to come by for our cars. Coilovers would probably be the best bet for improving our suspensions at the moment, yet they are pricey IMO.
AKSubie is offline
Old 12-10-2002, 07:33 PM
ted1186's Avatar
Well, I have the WRX wheels with the stock WRX tires on them. Should I still upgrade the rubber first or not worry about it for a while. It's winter here and I wouldn't upgrade the tires until about March anyways. My first mods are for the suspension.
The general consensus is that the rear sway bar is a very good mod for the money then? How much will that set me back?
ted1186 is offline
Old 12-10-2002, 11:03 PM
AKSubie's Avatar
IIRC, the stock WRX tires are the same that we have on the BE's (well, for the GT anyway) which are the famed re92's. Yes, you would probably still want to upgrade your rubber to improve the effect of the swaybar.
I think the swaybar is a good investment, and depending which vendor you go through it should run around $150 plus shipping, then another ~$40 if you go for the bushings. A vendor which I know has the bars currently is Teagues auto (www.teaguesauto.com) infact he told me he had several of them in stock when I ordered my front bushings. Very nice guy.
AKSubie is offline
Old 12-11-2002, 04:26 PM
ImprezaRSDriver's Avatar
Not entirely true. I believe the speed ratings that the Legacy's get is an H speed rated tire while the WRXs get a V speed rated tire.
ImprezaRSDriver is offline
Old 12-11-2002, 05:12 PM
ted1186's Avatar
Well, I did replace the Legacy L steel wheels and hubcaps to the WRX wheels and tires. The tires, if I upgrade them, will have to wait until the spring not only because it's winter, but also because I need income (I'm a highschool student BTW).
Thank you for the info.
ted1186 is offline
Old 12-24-2002, 11:36 AM
AKSubie's Avatar
Yeah, no kidding. Welcome to version 2.0!
AKSubie is offline
Old 12-29-2002, 07:27 PM
ted1186's Avatar
Thank you very much Heather, all of your posts were very helpful.
I'll be purchasing a Whiteline in the very near future.
ted1186 is offline
Quick Reply: Rear sway bar or springs
