Rear end thump with Rear ASB
Old 01-09-2003 | 09:27 PM
EtchyLives's Avatar
Question Rear end thump with Rear ASB
Prior to my first auto-x, I installed the whiteline adjustable rear anti-swaybar (furthermore known as ASB). After taking my four runs, with the ASB set on the lowest setting, I drove to McDonalds for lunch. Occasionally my passenger (InFeK) noticed that the rear end made a thumping noise.
I noticed it too for a dew days, and then it disappeared.
Prior to the last Auto-X I added a front ASB and endlinks and increased the rear to the highest setting.
Result: No more thumping.
Question: What was the thumping?
It happened as I was coming out of the corners and the cars' weight shifted back center.
-Thanks
Old 01-12-2003 | 07:58 AM
bamfwrx's Avatar
Car Info: 02 WRX
I have heard before on the forums that the bolts for the rear links are slightly smaller than the holes and will make a clunk noise if the work loose
just an idea
Old 01-12-2003 | 06:23 PM
EtchyLives's Avatar
Thanks for the response. It's better now, and I just got back from another Auto-X and no more noise. I was just kind of curious.
adriandjesus
03-27-2013 12:54 AM
maverick707
02-24-2006 10:45 PM
jimtweet
07-19-2005 06:57 AM
escaflowne
01-10-2004 04:57 PM
Shiseiji
08-28-2003 03:41 PM
