Question about stiff breaks in the morning?
Old 10-01-2004 | 04:53 AM
jasno999's Avatar
Car Info: Blaze yellow WRX 2002
Recently- I would say in the past 2-3 weeks I have noticed somehting very strange with my WRX. Every morning when I get in the car before I start it up I press down on the break. Well normally it would have a normal feel to it and the pedal would move a little before it came to a stop- jsut like when you are driving.
However in the past few weeks when I go to push on it the pedal does not move at all. It is totally stiff and has no play until I turn the car on and then it moves down slightly when the engine is started.
What could this be? Is there something that can explain this and is it somehting I should worry about or look into?
Old 10-01-2004 | 05:35 AM
04blkWRX's Avatar
Car Info: Black WRX, stock
I had that question too, it seems that the power braking system bleeds all its pressure overnight so you have no assistance in pressing the pedal.
Once you start the car everything is back to normal because everything is pressurized.
Old 10-01-2004 | 10:11 AM
jasno999's Avatar
Anybody else?
Old 10-04-2004 | 05:20 AM
jasno999's Avatar
Really my breaks feel stiffer while driving now too. What could be going on?
Old 10-04-2004 | 05:45 PM
PJ2.5RS's Avatar
You can 'pump up' the brake pedal w/ the car off, but after a point, just gets harder to push down etc? Isn't that normal operation?
I forget the exact workings of the system, but when the car's not on, the master cylinder can't circulate fluid (?). Similar to the power steering system.
Old 10-05-2004 | 05:03 AM
jasno999's Avatar
No I totally understand that. I agree if you pump the breaks it gets harder and harder to push the pedal down. However I am not pumping the breakrs or even touching the pedal while the car is off yet I get back into the car in the morning and the pedal feels as if somebod had pumped it a few times durign the night and that is not happening.
Since this has never occured before it makes me think somehting is going on with the break syatem. That is whay I am tryign to figure out.
BlackTzak
05-02-2006 05:06 AM
simbey1982
09-06-2005 03:58 PM
iLUvMyADioSHoes
05-13-2005 02:52 PM
SubySal
07-02-2004 04:13 PM
mmboost
05-21-2003 06:26 PM
Quick Reply: Question about stiff breaks in the morning?
