Perrin 4 piston calipers
Old 04-05-2004, 05:07 PM
Uncle Scotty's Avatar
Get the Subaru 4-pots and don't look back...
Those and the rest of what you're talkin' about rocks....that's what I got.
Lotsa people didn't like all the noise of the Perrins....they are, really, track brakes....and the Subaru 4-pots are just about as bomb proof as can be had.
Uncle Scotty is offline
Old 04-05-2004, 05:28 PM
r_master's Avatar
Car Info: PSM WRX
isn't brake noise usually caused by the type of pad not the caliper?
r_master is offline
Old 04-06-2004, 07:54 PM
Originally posted by punkrocksailor
I heard there was a lot of deflection and wobble with the 4pots and aren't they heavy as hell???
Cheers,
Joel
The Subie ones????
They ARE cast iron...like the stockers....but that's IT...
Deflection???? Wobble???? THAT'S the Perrin/Wilwoods....NOT the Subie ones.
Old 04-09-2004, 12:33 AM
www.subaruwrxparts.com
$700 includes everything you need. The pads and rotors that come with the kit are GREAT, especially considering they only cost $200 for pads AND rotors.
Kevin M is offline
Old 04-12-2004, 09:39 PM
SsTiNgEr77's Avatar
Car Info: 2002
hmm
ban suvs... the perrin 4 pots come with rotors? I've never seen this... they come with pads and ss brake lines to my knowledge.. plz show me where you got this info thanks!
SsTiNgEr77 is offline
Old 04-12-2004, 11:40 PM
Re: hmm
He's talking about the Subaru 4-pots
Old 04-18-2004, 01:48 PM
huck's Avatar
Car Info: 2013 GR STi
Those Subaru 4-pots are for the WRX correct? They just require aftermarket wheels to fit under?
huck is offline
Old 04-22-2004, 07:20 AM
xleratedwrx's Avatar
Car Info: 2002 2.5 Rs To4E
noise
I have had the new perrins on for months and not a peep from them, people ask me about it and wonder. I use them with DBA rotors and ss lines f&r it is seems to work fine.
xleratedwrx is offline
Old 04-28-2004, 04:48 PM
psychobooe's Avatar
I would stay away from the DBA rotors. I've heard of cracking issues with these. Cross-drilled rotors are just for bling. I'm going to with some Carbotech or maybe Stop-tech slotted rotors.
psychobooe is offline
Old 04-28-2004, 05:05 PM
actually
actually my DBA rotors are just slotted and I have heard of the same issue with drilled rotors.
Old 04-28-2004, 08:45 PM
psychobooe's Avatar
Sorry about that. I thought that DBA only made slotted and drilled ones. I'm sure their slotted brakes are fine.
Quick Reply: Perrin 4 piston calipers
