Parking brake light stays on ???
Does anyone know what problem may cause my parking brake light to stay on even when the brake is off? Sometimes it will even go off and then come back on again. I had SS lines, Axxis Deluxe Pads and Motul 600 put on a few months back, but this light thing just started...
The light will come on if the level in your brake fluid reservoir is low. It's low for a reason. Check for leaks and or worn pads. Incidently DRL will be disabled too when the light is on. Mostly because the light comes on when the E-Brake is up.
WRXakaBooSTi
01-28-2006 09:46 AM
