Outside tire wear - 04 sti
Old 09-07-2003 | 10:31 PM
2fcknfst's Avatar
Car Info: 2002 3/4 ton Cevy Suburban, 1997 Integra Type-R, 2004 WRX-STI
I seem to be having interesting wear on my stock POtenzas. They are wearing on the outside of the tire, rather than on the inside. This is only happening on the fronts, the rears appear to be fine.
I have lowered it about 3/4 of an inch, and had the alignment done back factory specs, or as close as possible.
I suppose I was expecting them to wear on the inside, as other lowered vehicles I have do.
Is this happening to anyone else, and is there a way to correct it?
Cheers.
Old 09-07-2003 | 11:36 PM
dropkick_muppet's Avatar
Car Info: '03 PSM Sedan
my '03 WRX w/STi suspension wears the outer egde of the tire more than any other part. this usually happnes because of hard cornering, and the sidewall of the tire rolling and flexing. check your tire pressures, the stock tires on the STi should have a stiffer sidewall than the RE92s. other than that, i'd say it's normal if you corner hard.
Old 09-08-2003 | 12:10 PM
2fcknfst's Avatar
So that would, in effect, seems to have the opposite effect when lowering your car?
How strange.
Old 09-08-2003 | 12:27 PM
my car is lowered maybe 1/4"-1/2" with STi struts and springs, and i'm running -1 camber up front. it wore the same way when i had the stock springs and struts on, so i don't think it's a byproduct of lowering the car.
CTrexfan
04-21-2004 12:49 AM
Scooby_WL
10-03-2003 12:24 PM
MZM
09-08-2003 12:20 PM
djcttb
04-28-2003 11:52 AM
pdqwrx
02-08-2003 11:36 AM
