Lateral Links/Trailing arms= Loud usually thudding?
Car Info: 2005 WRX
Hi everyone, I just bought some Cusco Lateral Links/Trailing arms and had them installed. I also did an alignment as well because I was having major positive camber. Now everytime I go over a bump I hear loud thudding on the rear passenger side. I am not sure if its the lateral links/trailing arms acting up or is this a different problem like maybe a strut? The car is not lowered, there are only a few suspension mods which are listed below:
Stock rims with 22/50/16 tires
Cobb Rear sway bar on second setting.
Whiteline rear endlinks
Cusco lateral links/trailing arms
Car is a 2004 Subaru Impreza WRX and is not lowered. I was thinking about tearing out the rear seats to figure out if a bolt or something was loose or the strut bolts themselves were loose.
Please help if possible, thanks.
have you checked to see if the sway bar flipped and or a sway bar bushing popped out?
Car Info: 2005 WRX
Front Left: Front Right
Actual: Before: Actual: Before:
-0.4 -0.9 Camber -0.4 -0.5
3.3 2.7 Caster 2.9 3.0
0.01 -1.09 Toe 0.00 0.86
14.3 14.8 SAI 14.6 14.8
13.9 13.9 Included Angle 14.2 14.2
Rear Left:
-1.0 -0.3 Camber -1.0 -0.4
0.01 2.45 Toe 0.00 -0.03
Rear Left:
Krang
Hawaii Classifieds
09-20-2012 10:40 PM
EBTurbo
Subaru OEM Parts For Sale
06-08-2008 01:35 PM
Silver Mojo
04-11-2004 03:46 PM
Andersonwrx
02-05-2003 04:04 PM
