If you thought carbon/ceramic brakes were sexy....
It won't catch on outside of maybe ice racing and rally. Why? Because who wants to have 10" brake rotors under their wheels when their vented, slotted 14" rotors work great already? Not to mention the cost factor.
It's neat, but I don't think it'll catch on. It has the possibility of being heavy, and the more complicated it gets, the less reliable things tend to be. It's some cool engineering though.
@Stoptech
Car Info: 2002 WRX Wagon
My guess is the first place you'll see this showing up is 3/4 and 1 ton pickups and SUVs. They will be able to use smaller wheels, save weight, and dramatically improve braking. The guys that are actually hauling heavy loads don't have the option to move to bigger wheels to accomodate bigger rotors due to tire constraints.
Tim
Tim
@Stoptech
Originally Posted by Grintch
Seems to me that the differential cooling of the rotors (inner rotor surfaces would get less cooling/retain more heat) would make them very prone to warping. Plus a lot of rotating mass compared to a standard system.
As far as rotating mass goes, this system has two solid rotors which would not dramatically affect rotating mass. Yes, you have two "hats" to connect the two separate rotors, but a normal vented rotor will still have those two rotors, they are just connected by vents in the middle. Those vents do have a significant amount of mass which adds thermal capacity and create much more surface area to aid in the dissipation of heat as well. My intuition tells me that this is designed more for heavy trucks where vehicle velocity is generally lower and wheel size is the limiting factor, rather than performance applications.
Tim
www.stoptech.com
Tim, what would happen if you milled out the vanes from your widest vented disks? Cooling would go to hell right? Now add additional piston acting on those additional surfaces, more heat generated - still crappy cooling - you would have a big problem.
Admittedly designing from scratch would allow you to optimize, but I doubt this would ever be a performance system. Even for a heavy truck, that heat would concern me. For truck isn't fade an issue while going down long downgrades?
@Stoptech
Quote by Grintch Tim, what would happen if you milled out the vanes from your widest vented disks? Cooling would go to hell right?
Quote by StopTech Those vents do have a significant amount of mass which adds thermal capacity and create much more surface area to aid in the dissipation of heat as well.
Quote by Grintch Now add additional piston acting on those additional surfaces, more heat generated - still crappy cooling - you would have a big problem.
Quote by grintch Admittedly designing from scratch would allow you to optimize, but I doubt this would ever be a performance system.
Quote by StopTech My intuition tells me that this is designed more for heavy trucks where vehicle velocity is generally lower and wheel size is the limiting factor, rather than performance applications.
Tim
www.stoptech.com
ryball
02-11-2005 03:15 PM
Krinkov
10-29-2004 08:30 AM
