How do I adjust Cusco Comp-2s?
Car Info: Impreza
I purchased a set of used Cusco Comp-2s and I don't know the proper way to adjust them. Can I turn them clockwise and counterclockwise? How do I know which number setting is selected? Is there a pdf manual floating around?
Does anyone have recommended settings?
Admin v2.0
Car Info: 02 Black Legacy GT
There should be numbers on the top of the strut. 1,2,3,4,5. I recommend using 2 or 3 if you like it more agressive. 4 and 5 will not do any good unless you are running super sticky tires or have lots of weight in the car.
You can turn them any way you want as many times as you want. You cannot over clock them (like TEINs for example).
Let me know if you have any more questions,
- Alex
- Alex
BrendanTheGreat
07-25-2014 12:31 PM
injected
02-15-2004 09:17 AM
