HOLY MOLY!! HELP!!!! My rear end is screwed.
Car Info: 95 1.8 fwd auto -> 95 2.5 awd 5sp
Ok, so making the long story short:
I am converting a 95 1.8 fwd impreza into a 2.5 awd impreza.
Fuel tank swapped with no problems, rear end went on perfect, all the holes matched up....
Installed shocks, and this is what i got:
Car Info: White on Gold STi
you got what a broken MRT endlink????? If your worried about that you haven't done a hole lot of reading on the board because I've seen at least 4 sets of those break in the last year.
Mike
Mike
thanx, i am at ease now. I went to dealership today, and he said that they have not a 2000 impreza for a while and that rear end on a vagon might be different....but it looked the same
I'ma go put the engine in... breed brakes, bleed clutch...bleed power steering...flush antifreeze....put a couple more cuts on my already covered in oil hands...
thanx
thanx
