Help. I want stock ride with 1" lower
...but I don't want to do the stock struts with lowering springs due to the wear issues. I love being able to blow over poles at 60 mph but want slightly more aggressive looking without tearing up the bottom of my car on every speed bump.
Car Info: 2003 WRX Wgn
You can try the Whiteline Control springs (15-40mm drop), and from what I understand they work well with stock struts in terms of wear.
http://www.whiteline.com.au/
Re: Help. I want stock ride with 1" lower
Location: We are the all singing, all dancing, crap of the w
Car Info: '09 Black Audi S5
I have Prodrive. Perfect. See www.fastwrx.com for b4 and after pictures of the drop.
I belive prodrive would be your best choice as stated above. They wont kill your ride (they are stock equipment on the UK spec STi's) wont lower it too much, adn they look great.
Cheers
-Jeff
Cheers
-Jeff
Car Info: Silver 2002 WRX Sedan
s.g.d
Prodrive will actually give you a nicer drop and a better ride. SPT is stiffer and does not lower the car noticeably
Silver arrow
I'm inclined to recommend Espelir. Cheaper than Prodrive, but just as good!
Silver arrow
It depends on which model year the springs are for, not the brand of springs. The '04 rear strut tops are different than the '02-'03s. If you want to put springs for an '02 on an '04, then you also need the strut mounts from an '02.
Originally posted by trebsrex
How about the espelirs do you need special tophats on those to make them fit 04 or do they have them out already for 04's??
One more thing where do you order espelirs and how much??Thanks for the inputs..
