Got Springs? (how low can I go on MY02 WRX)
Old 09-29-2004 | 10:42 AM
RussA's Avatar
Car Info: Aspin '02 WRX sedan
Originally Posted by Enash99
Hello all I was wondering if anyone can tell me what the maxium I can lower my 02 WRX with out having to install a camber kit? I was looking at buying a Tein spring kit taht has a 2" in the front and a 0.7 in the rear. I would really rather have a set that gave the car a more balanced stance if anyone could recommend a good set for the street please let me know. FYI I am planning on a set of 17" 225 size tires.
TIA
Shane
You should go with the STI Pinks. They are pretty much made for the car, they will lower it 1" front and back.
Or you could go with the Prodrive Springs, designed specifically to work with the stock struts of your car. It will lower your car about 1" in the rear and about 1.5"s in the front.
Old 09-29-2004 | 04:29 PM
ish's Avatar
ish
i would suggest going through the performance forums and read up on whats available and what others recommend. check out the suspension forum and the wrx powerplant forum as for other mods.
as for your questions, you will not need to buy a "camber kit" with just springs. there are camber bolts stock in the front. however its always a good idea to get some rear camber bolts to install with it so you can adjust the rear. if you go with coilovers then a lot of people install camber plates so they can easily adjust camber as needed.
as for a bov, read up in the other forums. the debate of wether a bov is benefical or even hurtful to a fairly stock engine has been discussed many times. although most people do bovs for the bling factor.
Old 09-30-2004 | 11:05 PM
mmboost's Avatar
Say good buy to your struts in about a year.
jason
Old 10-18-2004 | 02:24 AM
mxspl807's Avatar
Car Info: Impreza
go with espelir asd springs bout 1.5 fnt and 1 rear
https://www.i-club.com/forums/showth...=44105&page=17
Old 10-18-2004 | 11:31 AM
WindingRoad's Avatar
Car Info: 2004 White GDB
I think you would have to get an alignment once you install the springs anyway. But, you would also have to buy camber bolts if you want to drop it lower than about 1.5 inches.
harpoonflyby
01-26-2006 10:48 AM
WrexSy
04-01-2005 01:03 AM
OwlBoogie
05-27-2004 03:34 PM
kevster
12-04-2003 08:47 AM
Quick Reply: Got Springs? (how low can I go on MY02 WRX)
