Going to a larger rear swaybar will reduce understeer?
Car Info: 2005 WRX STI
When I finally get around to it, I think I'm going to go with a Whiteline 27mm adjustable front, a 24mm adjustable rear, and add the anti-lift kit. The car also needs an alignment so I could have a little negative camber dialed in there. Thanks for your help, guys.
Car Info: Silver 09 STI
Originally Posted by iceman302
When finally get around to it, I think I'm going to go with a Whiteline 27mm adjustable front, a 24mm adjustable rear, and add the anti-lift kit. The car also needs an alignment so I could have a little negative camber dialed in there. Thanks for your help, guys.
Do you see any negatives with that setup and my stock struts and Prodrives?
Originally Posted by BAN SUVS
The negative is that it won't give you the crisp turn-in a proper set of coilovers would, but it will be much more comfortable on the street. You'd have a pretty decent setup.
Car Info: WRX --> RX-8--〉E93
how long can the stock struts last with the aftermarket springs? what will happen if the struts go dead? so from what you guys saying from above, will the rear sway bar help the car handling in this case?
My .02 Cents!
I entered this a bit late. But I am running Subie Solutions/IPD/Rallitek bars and there is ZIP for understeer.
In fact, the handling on my wagon is dead *** the same as the '06 STI with the DCCD on auto (59% rear 49% front).
I am on the 7/8" front and the 3/4" rear set 'full hard'... I am so happy with this set-up, that running downhill (don't forget I have an N/A car) I am as quick in my wagon as I am in the STI.
The Evo still gets the edge on the same road however, but that's a different story all-together!
Originally Posted by EarlQHan
Unless you have a well damped coilover ;] But for someone looking to mod a street car, the price is usually too expensive.
subie OCD
05-05-2009 08:25 AM
links_courses
10-22-2003 02:44 AM
Tommy3rd
14
04-25-2003 05:15 PM
