ferodo ds2500 pads
Old 08-05-2004, 10:21 AM
coolamber's Avatar
ferodo ds2500 pads
Does anyone know where I can pick up some of these pads for my 04 STI? I cannot seem to find them here in the US....
coolamber is offline
Old 08-05-2004, 04:59 PM
www.racecompengineering.com has them in stock.
Kevin M is offline
Old 08-06-2004, 11:48 AM
@Stoptech
Steppin Razor's Avatar
Car Info: 2002 WRX Wagon
As do we here at StopTech.
Plus our prices are significantly better.
Thanks Kevin!!!
[muttersunderbreath]
jerk
[/muttersunderbreath]
Tim
www.stoptech.com
Steppin Razor is offline
Old 08-06-2004, 01:18 PM
west_minist's Avatar
www.subydude.com
www.rallispec.com
west_minist is offline
Old 08-06-2004, 01:29 PM
coolamber's Avatar
Thank you everyone that responded...
Old 08-06-2004, 06:29 PM
I have a question.
You normal have to do a conversion on the RS with a WRX kit.
Do stoptech have replace rotors for those wrx rotors?
If so, can you send me a link and let me see what those look like?
Old 08-06-2004, 06:37 PM
What conversion do you mean? Are you referring to the rotor/caliper bracket swap? If so, you would use standard WRX size rotors, which Stoptech of course stocks. You can see pictures on their website, www.stoptech.com.
Kevin M is offline
Old 08-06-2004, 06:42 PM
Thats correct.
Ok. I think I find them.
50-47011-101
50-47011-102
50-47012-101
50-47012-102
Do you have vented rear?
Old 08-06-2004, 06:46 PM
There are no vented rears for the stock brakes. You need to go to 2 pots or '05 Legacy rears for that.
Kevin M is offline
Old 08-06-2004, 06:47 PM
Ok.
Are the Legacy ones bigger or the same size?
Old 08-06-2004, 06:48 PM
Much larger. I'm also not positive yet that they will bolt up without modification, or at least using different backing plates.
Kevin M is offline
Old 08-06-2004, 06:50 PM
K. I will check here in Barbados. There have both in the 2004 model, which is the same.
Old 08-06-2004, 06:53 PM
Okay, the Legacy brakes will fit. Check it out- http://www.subaruwrxparts.com/gc8-braking.html
Kevin M is offline
Old 08-06-2004, 07:03 PM
Isn't the H6 Rear Brake Upgrade bigger than the Legacy Turbo Rear Brake Upgrade.
Ok. It doesn't look so from the price.
Old 08-06-2004, 07:13 PM
The new ones have updated calipers and vented rotors. For the price, I'd get the '05 stuff over the "H6" swap.
Kevin M is offline
Quick Reply: ferodo ds2500 pads
