cusco sway bars + endlinks?
are aftermarket endlinks needed when running cusco sway bars? if so any recommendations. i have stance gr+ sti lateral links. waiting on cusco f/r type os struts. looking to get cusco f/r sways. any help is greatly appreciated
Endlinks will make the sway bar work more efficiently. Its not needed but it will increase performance... just depends on how much 'give' you want to eliminate. That make sense? If not, go under the car and look at the sway bar and endlinks - you'll see that the stock endlink is a hard rubberish material that can flex and give. Bigger sway bars will reduce body roll... bigger sway bars and endlinks will reduce it even more. If you're not sure on what you want, you can always install the bar first, then add the endlinks if you want more.
hayakunai
10-10-2006 03:12 PM
adamsrs
07-22-2004 06:18 PM
