clunking niose after coil spring install
Old 03-31-2003, 10:58 PM
What springs are they? If they are a severe drop, you could be drooping far enough to lift them off the strut plates.
Kevin M is offline
Old 04-01-2003, 07:13 PM
Originally posted by hackjar
Where does the clunking sound come from? If its from the rear it could be from the swaybar hitting the muffler. Do you have an aftermarket swaybar? This happened to me (without the lowering springs). I'm just going to get a magnaflow muffler that is 2"shorter than stock for about $130 installed, should solve the problem nicely.
You could be on to something. I wonder if the front bar will hit anything when lowered.
Kevin M is offline
Old 04-01-2003, 10:58 PM
I'm still using stock exhaust and I have a 20mm FHI RSB, so I doubt I need to check. I'll be sure to bring it up when I get my exhaust fabbed up next month though.
Kevin M is offline
Old 04-08-2003, 04:33 PM
mysubaruimp's Avatar
Car Info: 2001 sub. imp.
there is one washer on the top of each strut, right under that first nut you have to undo to get the bearing plate off. if the washer is left out, it will make a clunking noise over bumps.
mysubaruimp is offline
Old 04-16-2003, 10:30 AM
WRX34's Avatar
Car Info: 2002 WRX
Check the plate under the front swaybar...in the ALK you get washers that gradually displace the subframe alowing more room for the components but I'd take a look there and maybe grab some washers from Home Depot to allow those few extra mm for clearance of the front sway...esp. if u have the whiteline sway that some people complain about clunking also. As for coilover sleeves..they will always be a bit noisier than a spring..lowring springs and any suspension needs some time to settle but shouldn't be that long.
WRX34
WRX34 is offline
Old 04-20-2003, 11:38 PM
Maybe this problem has something to do with it. Check the last post, it's a thread about the P1 suspension on ScoobyMods.com.
Kevin M is offline
Old 04-22-2003, 09:35 PM
Shouldn't be. They give you the shorter bumpstops to maximize the travel you have left. The new stops should be noticeably stiffer when you were holding and installing them. Now, if you had left them off completely that might cause it.
Kevin M is offline
Quick Reply: clunking niose after coil spring install
