changing my pads (service manual specifies use of Molykote)
Old 06-21-2005 | 07:37 PM
FourStar's Avatar
changing my pads
im changing my brake pads right now using the Subaru shop manual off of a cd, and it says to apply a thin layer of molykote between the pad and the rotor. what is molykote? is it absolutely necesary to apply it? and are there any substitues? thanks
Old 06-25-2005 | 11:33 PM
a little late on the responce
i didnt put anything and i dont have noise
Old 06-26-2005 | 12:40 AM
Wingless Wonder's Avatar
Dow Corning Molykote® AS-880N. It's a high temperature silicone grease that helps prevent squeaking or binding on brake parts. Don't use another product unless recommended for the same type of application (i.e. don't use white lithium grease). I didn't use it when I replaced my front and rear pads but if you can find Molykote® AS-880N at NAPA, I would go ahead and use it as recommended by the service manual. My brakes don't squeak (so far).
Origami posted by FourStar
...it says to apply a thin layer of molykote between the pad and the rotor.
You might want to check the manual again. It has diagrams showing where the Molykote® should be applied. Don't apply anything between the pad and the rotor, especially grease!
Teck2018
12-12-2005 10:26 PM
n192da
08-04-2005 05:36 PM
t3ch9
11-01-2004 03:03 PM
DJ Catchem
12-19-2003 12:20 AM
