Brake upgrade w/ limitations
Old 11-22-2005 | 09:08 PM
dypeterc's Avatar
Car Info: 05 WRX
I've got an '05 WRX and would like to upgrade the brakes. I don't want to do a big brake kit because I want to use the stock 16 inchers for winter. It's no problem finding replacement slotted or cross-drilled rotors that are the stock size but I'm having trouble finding an upgraded caliper. I'd also like to stay away from Brembo. Maybe something from AP Racing, Wilwood, or Stoptech. Any ideas? Hope I'm not reposting. Thanks
Old 11-22-2005 | 09:30 PM
ipozestu's Avatar
Car Info: Broken Subarus
If you want to stick with 16" wheels you are pretty limited in upgraded calipers. Although some Carbotech Bobcat pads, Motul Fluid, SS lines, vented rotors and MC bracket make for a very nice upgrade to the stock system. I am going to be puling off a set of Centric Slotted Rotors and Hawk pads in a week or so if your interested. There are about 5000 miles on them.
Old 11-24-2005 | 01:32 AM
taerron's Avatar
some of the 4pot subaru sti calipers will still work under the 16's and the wilwood and perrin 4pots will too.
Old 11-24-2005 | 04:48 PM
scrWrx's Avatar
Car Info: 05 WRX
heres some of the sti calipers taerron was talking about, https://www.subarugenuineparts.com/i...hp?cPath=33_68 , i was thinkin of gettin them too since i want up grade but im leaving stock rims since im going for a sleeper. the only exterior stuff is the "I" badge and STi scoop (ordered yesterday) i need to get some other rims but i want STi bronze, hard to find.
Old 11-24-2005 | 09:04 PM
taerron's Avatar
i'm considering those 4pots too. i don't track so right now, i just upgrade my rotors and pads for now.
Old 12-22-2005 | 10:50 PM
dypeterc's Avatar
Car Info: 05 WRX
Thanks for the input. I'll probably upgrade to the STi 4-pots as well. One of these days...
Old 01-11-2006 | 10:00 AM
04whitewrx's Avatar
Car Info: 2004 wrx
if you're looking for better braking, you might consider the rear h6 upgrade as well. the only thing you need are rotors from a legacy with a 6 cyl and the rear caliper brackts from the same car. and change the pads of course. you'd be amazed at the difference.
Old 01-11-2006 | 11:48 AM
ProPartsUSA's Avatar
Car Info: WRX
I was just curious, What year Legacy are you referring to?
Old 01-11-2006 | 12:02 PM
04whitewrx's Avatar
Car Info: 2004 wrx
i used rotors and brackets from a 2000 ll bean.
Old 01-15-2006 | 07:13 AM
taerron's Avatar
just got a set of wilwood 4pots for the front. great improvement over stock and i still can run 16's with it. not bad for the price either
Attached Thumbnails Brake upgrade w/ limitations-simg0013.jpg
Old 01-16-2006 | 02:27 PM
04whitewrx's Avatar
Car Info: 2004 wrx
sorry i took so long to reply, but here is a walkthrough.
http://www.scoobymods.com/forums/showthread.php?t=3733
Mootis
01-05-2005 02:53 AM
Keisatsu
07-28-2003 03:26 PM
bseeling
07-26-2003 02:22 PM
Driveway
01-22-2003 03:13 PM
Quick Reply: Brake upgrade w/ limitations
