brake rotor replacement
Car Info: 2003 WRX Sedan
i wanna buy some new drilled racing brake rotors for my 2003 wrx sedan. i was wondering what sized rotors i need to fit on the stock calipers? what are good looking rotors that you guys might suggest getting?
thanks
thanks
Car Info: '94 WRX, '97 Forester S/Tb, '95 WRX-RA
StopTech makes good OEM replacement rotors for around $95 each. I would suggest going with slotted instead of drilled, unless you really only want them for looks.
www.stoptech.com
www.stoptech.com
Location: EBAIC- Wondering if I should have taken the blue pill...
+1. Drilled rotors have more of a tendancy to crack under extreme heat. I think you can pick up good, quality slotted rotors cheaper than $95 a piece, though. I dunno, that seems alittle steep to me..
SubySal
12-03-2003 08:22 PM
