Brake Pad Life
Car Info: '04 WRX Wagon - Java Black
Brake Pad Life
I have an '04 WRX Wagon. It has just under 26,000 miles. I was at the dealer to have oil/filter change as well as to address a "brake" light warning. They called me later in the day to say that the pads are shot. They measure 2-3/32" of pad material on all the wheels.
While covered under warranty, is this useage typical? My reference points are two VW - one- front pads lasted 60,000 miles, on the other one, 120,000 miles. 26,000 just doesn't seem so good in comparison.
Thoughts?
Thoughts?
Yes and no- they don't wear the brakes faster, they make you use them more. Not sure if that makes sense or not. Basically, if you *never* engine brake with your manual, you would wear the same as if you had an auto (or possibly slightly faster, as there is a slight engine brake with the slushbox).
Originally Posted by Lorry
Yup, that's kinda what I was assuming. I see a lot of people in the Sierras riding the brakes on the hills instead of using the engine.
BRAKE LIGHT ON?!?? and HAWK HPS pads
A few weeks ago my brake light came on and would not go away regardless of e-brake position. Occasionaly it would go away during shifting. I thought that it was a loose wire that was causing a short due to changing acceleration forces. It has since gone away. Now i just read something about a "brake warning light" is this what I was experiencing?
I have 35,000 miles on stock pads and have heard huge variations on brake pad life. I have have had no problems with the brakes and hear no squeeling. Is this long life unusual? I even have about 10 autocrosses on these pads.
I figure it is time for an upgrade anyway...anyone have any experience with Hawk HPS Street pads? Any comparisons between the Hawks and Axxis Ultimates? Thanks
msg101
05-01-2003 01:18 AM
