Brake Failure -- Dealer to Blame?
Car Info: 2006 STi
![Exclamation](https://www.i-club.com/forums/images/icons/icon4.gif)
RESOLVED: See post on page seven for the details.
Hi all,
I just experience a pretty significant brake failure (driver's side rear brake) and some investigation is leading me to believe that it was caused by my Subaru dealer's incompetence last time I took it to get serviced. I'd like to get your input to see what you think.
What Happened
I was driving home yesterday from work and, at one point, had to brake hard when I was cut off. Didn't notice anything odd. Later, however, as I was exiting the freeway, I noticed a whirring sound from the rear and the car dragged as if it had a flat tire. Upon pulling over, however, I noticed clouds of smoke pouring out of the driver's-side rear wheel. This is what I saw:
![](http://homepage.mac.com/jhammer/sti/fire.jpg)
That's a very hot disc. And yes, those are flames.
So after things had cooled, I jacked it up and pulled the wheel off. The caliper was fried to a crisp:
![](http://homepage.mac.com/jhammer/sti/crisp.jpg)
On closer inspection, however, I noticed that the brake line heading to that caliper appeared to have a steel clamp on it, restricting the line:
![](http://homepage.mac.com/jhammer/sti/clamp.jpg)
Diagnosis
So here's what I think happened. A couple months ago I took my car to the dealer for it's 30k mile service. The service rep. said that the rear brake pads were ready to be replaced and that they'd replace them under warranty. Great. However, it appears that whoever did the service clamped the brake line (possible when they were bleeding the brakes) and forgot to remove the clamp when they were done.
I had noticed the past couple of months that that particular disc was perpetually rusty -- as in I suspected that perhaps something was wrong w/ the caliper and the pads weren't ever being applied to the disc to remove the thin layer of oxidation on top. I was new to my STi, so I wasn't able to tell if braking performance was degraded at all.
Yesterday on the freeway when I slammed the brakes, I'm guessing brake fluid made it past the clamp, activated the caliper, but then, when I let off, the fluid wasn't able to escape back up the line because it was blocked by the clamp. Hence brake stayed locked.
It seems pretty clear to me that this is gross negligence on the part of the dealer. What do you think?
Thanks for your help!
Jonathan
Hi all,
What Happened
Diagnosis
Jonathan
wow! that is hella dangerous. I never seen a rotor like that from normal driving. the dealership covered yoru brakes under warranty?
sounds liek what you described happend. i would def call the dealership and have someone come out. dont mess with anything so they cant blame you. tell them that whole story and keep us updated.
take pics more pics. take a 100 pics, take every angle you can get. they will try to **** you. call them right now. if they dont take car of it start tellign them you will take care of it by legal means. that is ****ed up man. i tell you what if that was my car, and my son was in it with me when that happend. i would be in someoens face at the stealership right now.
the onyl thing that might try to come back at you with is that you thought something might be wrong and you didnt bring it back, but dont take that ****. regardless if you brought it back or not, it shouldnt have happend and they are 100% responsible.
![SHOCKED](https://www.i-club.com/forums/images/smilies/SHOCKED.gif)
Good luck man!
http://www.bar.ca.gov/01_ConsumerAct...nts/index.html
for CA
if you need other states or have questions post them or PM me
for CA
Old School
Car Info: '99 RBP GM6
How in the world did your car not just make a hard left turn on a locked back wheel like that, I just don't know.
That is amazing, you are VERY lucky to not have crashed. That's their fault and they better look over your hub/axles and diff as well.
-Gagan
-Gagan
