bleeding system
bleeding system
Its been a while since I have done this. Do you start with the closest wheel first or the furthest? And is it the wheel closest/furthest from the master cylinder or the ABS manifold?
About how much brake fluid will I need to flush the stock system in my Y2K Legacy.
Location: Flying on the H1 w/ 75 psi of compression on all 4 cyl
i not sure how different my rex is from your legacy but when you bleed a rex you start from the right front , left rear, left front and right rear. here is a picture for ya. and if you need more info check out www.scobbymods.com
Irish_car_B0mb
04-04-2012 02:26 PM
XenoWolf
05-02-2005 07:36 AM
gqzboy
14
06-07-2003 07:50 PM
