Best Brakes for a '04 WRX
Car Info: 2004 Impreza WRX
whats the best brakes for a '04 WRX
maintaing the 16' wheels
here are some that i've found:
COBB Tuning
WRX Brakes-Stage 2 $545
http://cobbtuning.com/wrx/brakes2.html
Gruppe-S
Wilwood 6-piston Front (Drilled Rotors) $1295
http://www.gruppe-s.com/Subaru/subbrk.htm
Rallitek
ZMI Ti Brake System $3725
http://www.rallitek.com/products.asp...&HB=Y&ACC=&SP=
SubaruStore
Wildwood 6 Piston Big Brake Kit $1279.99
http://www.subarustore.com/wil6pisbigbr.html
Z-1 Performance
Brembo Sport kit (305mm rotors, 4 piston calipers, fits stock 16 inch wheels) $2099
http://www.z1auto.com/prodmore.asp?m...ing&prodid=211
All comments please welcomed!
COBB Tuning
Gruppe-S
Rallitek
SubaruStore
Z-1 Performance
It depends on what you plan to do with your car. If it sees track time, caliper upgrades wouldn't hurt. I think that Subaru 4 pots and StopTechs are basically the best choices, unless you're hellbent on using your stock wheels. Personally, I think it's silly to spend $1500-2000 on brakes and not get better ones because you don't want to replace a $250 set of wheels. If you don't see track time, just get pads, lines, and fluid like Scotty said. Lots and lots of discussion of those things in this forum.
you missed one. i just purchased it for my car and am waiting for it in the mail, so i can't comment on the performance of it.
Stoptech stage 2 kit
http://www.stoptech.com/STAGE1and2_020904_USD.pdf
front and rear rotors, axxis pads, ss brake lines, 3 bottles of motul rbf 600
$500
$500
Car Info: WR Blue WRX
jester - Yeah the best deal for you would to go with the Stoptech Stage 2 kit. This will give you new rotors, lines and pads for a very affordable price! $499 shipped!!
If you are interested in one then let me know!
https://www.i-club.com/forums/showth...threadid=23603
Brian
Flash N Dash Performance
Brian
Brian
Brian
Check out: http://www.twrracing.com
Their 310mm kit will fit under the stock WRX wheels. The guys at TWR are great. I bought mine through Aerosim Research (714-545-5679). Talk to Kym - she is awesome!
I was leaning towards these brakes due to the 2-piece rotor design and nice 4-piston calipers. The fact that the 310mm kit fits under the stock 16" wheels just sealed the deal!
$500
$500
getting close to the time of upgrading the brakes:
i wanna keep the stock 16" wheels, but add better braking power for everyday driving along with any addition i may choose in the way of engine power
so any input or suggestions on the above mentioned kits or any others is greatly appreciated!
If you got the money to burn....around $2,500( Ap racing 4 piston front brake kit) and for more, the mother of all jdm brake kits around $3,600(Endless 4 piston brake kit).
Both doesn't maintain stock wheels though, but some badass brakes!!
@Stoptech
Car Info: 2002 WRX Wagon
You can probably guess what my opinion is...
If your stock rotors are still within spec, your best value is going to be the Uncle Scotty special: Better pads front and rear, SS lines front and rear, and better fluid.
As you may or may not know, our Stage One kit includes Axxis Ultimate pads (StopTech Street Performance for 2003+ models) front and rear, StopTech SS brake lines front and rear, and 3 bottles of Motul RBF600 fluid for either $249 or $349 depending on whether you've got the older or newer calipers, respectively. You'll need to find out which calipers you have no matter what you do, so check this page out: http://www.stoptech.com/faq/data/faq29.htm
Those combos are extremely difficult to beat from a pure performance to price ratio, but the Ultimates and the StopTech pads do produce their fair share of dust. We feel it's an acceptable tradeoff for performance, but everyone has their own preference. Basically if you're looking for a pad that doesn't dust, these aren't the pads for you.
Let me know if you have any other questions.
Thanks,
Tim
www.stoptech.com
Thanks,
Tim
www.stoptech.com
