Bad pop when going into driveways.
Old 11-13-2008 | 05:18 PM
shauncovo's Avatar
Car Info: 2015 WRX
I recently installed some cobb springs on my sti a couple of days ago. Everything seemed fine until i went up a steep driveway and heard a pop from the the back right corner. I noticed that that side is little bit higher than the left and not sure what happened. I jacked it up and heard the pop again, not sure what it could be. I took my seats out and made sure the bolts were tight on the top but i think it might be something inside, I don't know everything looks fine. Any insight to this problem would be a help.
Old 11-13-2008 | 05:26 PM
jinorazi's Avatar
Car Info: 05 cgm imp
maybe the springs arent sitting in the grooves properly.
you can also try putting on washers about 2-3mm on the top 3 nuts.
good luck!
Old 11-13-2008 | 05:27 PM
VRT MBasile's Avatar
maybe the spring is not seated properly in the perch?
Irish_car_B0mb's Avatar
something not seated well? maybe unistall and reinstall. i know its a paint in the *** but you might wanna make sure nothign broke.
Old 11-14-2008 | 02:23 PM
tofuman's Avatar
Car Info: a blue car
^+1. Also, is the top hat in the right position? May be part of the issue with one side higher than the other and would cause the spring to not seat properly.
Old 11-14-2008 | 10:53 PM
jondl's Avatar
Car Info: 2007 WRX CGM
I was getting a popping noise on steep driveways too. turned out to be my WL sway bar. all i did was tighten up the bolts and now it happens once every blue moon still happens though. ;p
Old 11-17-2008 | 01:21 PM
XvPhoeniX's Avatar
Car Info: 2000 2.5 RS 4DR STM
I have the same pop and I think my sway bar is the source. Which bolts did you have to tighten?
UCLAjohn
11-19-2010 02:31 PM
Fendyman
01-05-2010 10:35 PM
PurduePhiGam
06-30-2005 02:10 PM
mexicanpizza
04-30-2004 05:08 PM
Liigod
11-01-2003 10:34 PM
